주요 콘텐츠로 건너뛰기
Dell Latitude E7440 CMOS Battery Replacement
필요한 것
  1. Dell Latitude E7440 CMOS Battery Replacement, Prepare the laptop: 1 단계, 이미지 1개 중 1개
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 CMOS Battery Replacement, Release the battery: 2 단계, 이미지 3개 중 1개 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: 2 단계, 이미지 3개 중 2개 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: 2 단계, 이미지 3개 중 3개
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 CMOS Battery Replacement, Remove the battery: 3 단계, 이미지 1개 중 1개
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: 4 단계, 이미지 2개 중 1개 Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: 4 단계, 이미지 2개 중 2개
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 CMOS Battery Replacement: 5 단계, 이미지 2개 중 1개 Dell Latitude E7440 CMOS Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 CMOS Battery Replacement: 6 단계, 이미지 3개 중 1개 Dell Latitude E7440 CMOS Battery Replacement: 6 단계, 이미지 3개 중 2개 Dell Latitude E7440 CMOS Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Position your nylon spudger on the edge of the white connector, in between the connector and the port.
    • Pull back on the connector until the plastic head disconnects from the port on the laptop body.
    • If the connector is stuck, move the broader end of the spudger back and forth across the connector to slowly loosen the connection.
  7. Dell Latitude E7440 CMOS Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Separate the wrapped battery stack from the body by pulling up the wire.
    • You may need to use the flat end of the nylon spudger to separate the battery.
    • The stack is attached using glue, so you might hear a pop when removing it.
    • Reapplying an adhesive to the bottom of the battery is recommended, although not necessary, to keep it in place.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Akash Kedia
회원 가입일: 01/24/19
1,526 평판
안내서 5개를 작성함
Cal Poly, Team S2-G5, White Winter 2019 Cal Poly, Team S2-G5, White Winter 2019 회원
CPSU-WHITE-W19S2G5
4 회원들
안내서 5개를 작성함
2가이드 댓글
You list no part number for the replacement battery. Do we know the part number? I looked on Dell's website and find nothing. Otherwise, nice write-up!
jess13j - 답글
@jess13j, battery is a CR2032 coin cell.
senzog - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 108
전체 시간: 15,180
