주요 콘텐츠로 건너뛰기
Dell Latitude E7440 Hard Drive Cable Replacement
필요한 것
  1. Dell Latitude E7440 Hard Drive Cable Replacement, Prepare the laptop: 1 단계, 이미지 1개 중 1개
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Hard Drive Cable Replacement, Release the battery: 2 단계, 이미지 3개 중 1개 Dell Latitude E7440 Hard Drive Cable Replacement, Release the battery: 2 단계, 이미지 3개 중 2개 Dell Latitude E7440 Hard Drive Cable Replacement, Release the battery: 2 단계, 이미지 3개 중 3개
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the battery: 3 단계, 이미지 1개 중 1개
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the bottom screws: 4 단계, 이미지 2개 중 1개 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the bottom screws: 4 단계, 이미지 2개 중 2개
    • EET owners: Your kit has this bit. No purchase needed.
    • After removing the battery, remove the 2 Phillips #0 screws securing the service panel.
    • Slide the panel off after removing the screws.
  5. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the original HD cable: 5 단계, 이미지 3개 중 1개 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the original HD cable: 5 단계, 이미지 3개 중 2개 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the original HD cable: 5 단계, 이미지 3개 중 3개
    • If your E7440 is missing the caddy or bumpers, these parts can be safely omitted if an SSD is installed. If your unit is complete, remove the 4 screws marked in red. These screws are Phillips #0 if your laptop has them.
    • Pull the tab on the drive cable up to disconnect it from the motherboard.
    • Deroute the hard drive cable from the system.
  6. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the drive and cable: 6 단계, 이미지 2개 중 1개 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the drive and cable: 6 단계, 이미지 2개 중 2개
    • If you are removing the cable to complete a different repair, do not use force.
    • Remove the drive from the machine, and disconnect the cable.
  7. Dell Latitude E7440 Hard Drive Cable Replacement, Install the new HD cable: 7 단계, 이미지 2개 중 1개 Dell Latitude E7440 Hard Drive Cable Replacement, Install the new HD cable: 7 단계, 이미지 2개 중 2개
    • Once the old cable is removed, partially install the replacement cable. Final placement is done with the drive installed.
    • Reinstall the drive into the laptop, and setup the final cable placement.
결론
작성자
2다른 기여자 명과 함께
Nick
회원 가입일: 11/10/09
93,664 평판
안내서 59개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 53
전체 시간: 1,122
