주요 콘텐츠로 건너뛰기
Dell Latitude E7440 Hard Drive Replacement
필요한 것
  1. Dell Latitude E7440 Hard Drive Replacement, Prepare the laptop: 1 단계, 이미지 1개 중 1개
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Hard Drive Replacement, Release the battery: 2 단계, 이미지 3개 중 1개 Dell Latitude E7440 Hard Drive Replacement, Release the battery: 2 단계, 이미지 3개 중 2개 Dell Latitude E7440 Hard Drive Replacement, Release the battery: 2 단계, 이미지 3개 중 3개
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Hard Drive Replacement, Remove the battery: 3 단계, 이미지 1개 중 1개
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 1개 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 2개 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 3개
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
    • Slide the service tray using the middle stand offs to then be able to lift the tray off.
  5. Dell Latitude E7440 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 Dell Latitude E7440 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Remove four M2 x 3mm Phillips #0 screws from the hard drive cage.
    • Remove the hard drive cage by lifting it off the laptop.
    • The hard drive cage is not pictured here, but the screws will be in these locations.
  6. Dell Latitude E7440 Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 Dell Latitude E7440 Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the hard drive connector from the top of the drive.
    • iFixit's device came without a hard drive to picture. Your device will have a component connected to the thin, black connector.
    • The hard drive connector can be removed from the laptop body to make replacement easier.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Akash Kedia
회원 가입일: 01/24/19
1,526 평판
안내서 5개를 작성함
Cal Poly, Team S2-G5, White Winter 2019 Cal Poly, Team S2-G5, White Winter 2019 회원
CPSU-WHITE-W19S2G5
4 회원들
안내서 5개를 작성함
3가이드 댓글
Hi, my problem is the opposite, I have an hard drive but seems like my HDD connector doesn't plug in the small port. I can send you a pic, I need help
†Winterfall† - 답글
I want to use a Seagate hard disk, but when I start it, it demands me a password. Can you help me in this case please?
Aldoni JB - 답글
It sounds like your BIOS is locked to only work with that hard drive
Magnus Vacuum -
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 21
지난 30일: 120
전체 시간: 13,047
