주요 콘텐츠로 건너뛰기
Dell Latitude E7440 Keyboard Replacement
필요한 것
  1. Dell Latitude E7440 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Slide the latch and remove the battery.
  2. Dell Latitude E7440 Keyboard Replacement: 2 단계, 이미지 1/3 Dell Latitude E7440 Keyboard Replacement: 2 단계, 이미지 2/3 Dell Latitude E7440 Keyboard Replacement: 2 단계, 이미지 3/3
    • Remove two 3mm screws using the Phillips #0 screwdriver.
    • Slide the access door down and remove.
  3. Dell Latitude E7440 Keyboard Replacement: 3 단계, 이미지 1/3 Dell Latitude E7440 Keyboard Replacement: 3 단계, 이미지 2/3 Dell Latitude E7440 Keyboard Replacement: 3 단계, 이미지 3/3
    • Unplug bottom cables.
    • Remove two 5mm screws using the Phillips #0 screwdriver.
  4. Dell Latitude E7440 Keyboard Replacement: 4 단계, 이미지 1/1
    • Remove keyboard bezel by using the opening tool to gently pry open the sides.
  5. Dell Latitude E7440 Keyboard Replacement: 5 단계, 이미지 1/2 Dell Latitude E7440 Keyboard Replacement: 5 단계, 이미지 2/2
    • Remove two 2.5mm screws next to the space bar using the Phillips #0 screwdriver.
    • Remove the mouse buttons carefully.
  6. Dell Latitude E7440 Keyboard Replacement: 6 단계, 이미지 1/3 Dell Latitude E7440 Keyboard Replacement: 6 단계, 이미지 2/3 Dell Latitude E7440 Keyboard Replacement: 6 단계, 이미지 3/3
    • Remove the three 3mm screws that are around the perimeter using the Phillips #0 screwdriver.
    • Slightly jerk the keyboard from one side before pulling it one direction.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Sheetal Prasanna
회원 가입일: 11/06/19
649 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G1, Stella Fall 2019 IUPUI, Team S1-G1, Stella Fall 2019 회원
IUPUI-STELLA-F19S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 2개
for step three i would add “ the cables to be removed are under a type of flap/cover”. I don’t know if we have to be specific on what tools we used. If we do have to be specific than we will just add them. Other than that great work!
Oscar Aca - 답글
In Step 3, there are four cables to remove, not three (one more to the left which is not highlighted in the picture).
Jamie O'Hare - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 36
전체 시간: 5,013
