주요 콘텐츠로 건너뛰기
Dell Latitude E7440 RAM Replacement
필요한 것
  1. Dell Latitude E7440 RAM Replacement, Prepare the laptop: 1 단계, 이미지 1/1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 RAM Replacement, Release the battery: 2 단계, 이미지 1/3 Dell Latitude E7440 RAM Replacement, Release the battery: 2 단계, 이미지 2/3 Dell Latitude E7440 RAM Replacement, Release the battery: 2 단계, 이미지 3/3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 RAM Replacement, Remove the battery: 3 단계, 이미지 1/1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 RAM Replacement, RAM: 4 단계, 이미지 1/2 Dell Latitude E7440 RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 RAM Replacement: 5 단계, 이미지 1/2 Dell Latitude E7440 RAM Replacement: 5 단계, 이미지 2/2
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 RAM Replacement: 6 단계, 이미지 1/3 Dell Latitude E7440 RAM Replacement: 6 단계, 이미지 2/3 Dell Latitude E7440 RAM Replacement: 6 단계, 이미지 3/3
    • For each RAM module, pull apart both the clips and remove the memory.
    • iFixit’s device came without RAM installed. Your device will have a module between each set of clips.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Akash Kedia
회원 가입일: 01/24/19
1,373 평판
안내서 5개 작성하였습니다
Cal Poly, Team S2-G5, White Winter 2019 Cal Poly, Team S2-G5, White Winter 2019 회원
CPSU-WHITE-W19S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 58
전체 시간: 2,488
