주요 콘텐츠로 건너뛰기
Dell Latitude E7450 Base Cover Replacement
필요한 것
  1. Dell Latitude E7450 Base Cover Replacement, Remove battery from computer: 1 단계, 이미지 1/2 Dell Latitude E7450 Base Cover Replacement, Remove battery from computer: 1 단계, 이미지 2/2
    • Before performing this task, make sure you turn off the computer and disconnect every external drive from it, whether it's a USB drive, power charger, or wireless adapter.
    • Slide the release latch to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Latitude E7450 Base Cover Replacement, Removing the Base Cover: 2 단계, 이미지 1/1
    • Remove the screws that secure the base cover to the computer [1].
    • Slide the base cover to release it from the computer [2].
  3. Dell Latitude E7450 Base Cover Replacement, Remove the base cover from the computer.: 3 단계, 이미지 1/1
    • Remove the base cover from the computer.
    • Place the base cover to align with the screw holes correctly on the computer.
    • Tighten the screws to secure the base cover to the computer.
    • Install the battery back on the computer.
결론
Hezekiah Brown
회원 가입일: 02/11/21
6,142 평판
안내서 50개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 263
