주요 콘텐츠로 건너뛰기
Dell Latitude E7450 Hard Drive Replacement
필요한 것
    • Before performing this task, make sure you turn off the computer and disconnect every external device from the machine, for example, USB devices, displays or power supplies.
    • Slide the release latch to unlock the battery before removing it. To remove the base cover, you should remove the Philips head screw on either end of the laptop in the battery compartment, before lifting it up from the screw hole side.
  1. Dell Latitude E7450 Hard Drive Replacement, Disconnect hard drive cable: 2 단계, 이미지 1개 중 1개
    • Carefully disconnect the Hard Drive from the cable, "walking out" one side at a time with a spudger to ensure you don't damage the connector.
    • Unscrew the retaining screws for the Hard Drive bracket.
    • You will now be able to remove the bracket, taking the drive with it.
  2. Dell Latitude E7450 Hard Drive Replacement, Remove hard drive: 3 단계, 이미지 1개 중 1개
    • Remove the computer’s hard drive.
    • Install the new drive into the drive bracket, before carefully reconnecting the drive to the cable, and seating it in place.
    • Put the hard-drive bracket on top of the hard drive.
    • Tighten the screws so that they can lock the computer’s hard drive.
    • Connect the hard-drive cable to the system board connector.
    • Install the battery and base cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Hezekiah Brown
회원 가입일: 02/11/21
6,277 평판
안내서 49개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 20
지난 30일: 77
전체 시간: 3,495
