주요 콘텐츠로 건너뛰기
Dell Latitude E7450 Memory (RAM) Replacement
필요한 것
    • Before performing this task, make sure you turn off the computer and disconnect every external drive from it, whether it's a USB drive, power charger, or wireless adapter.
    • Remove battery and base cover from the computer.
  1. Dell Latitude E7450 Memory (RAM) Replacement, Open retention clips: 2 단계, 이미지 1개 중 1개
    • Open the retention clips away from the memory chip.
  2. Dell Latitude E7450 Memory (RAM) Replacement, Remove memory chip: 3 단계, 이미지 1개 중 1개
    • Remove the memory chip from the computer.
    • Put a new memory chip in the memory socket.
    • Push the memory chip until the clips lock it. If a second memory chip needs to be installed, repeat steps 1 through 6.
    • Replace the pre-removal parts in descending order.
    • Install the battery and base cover back on the computer.
결론
작성자
1다른 기여자 명과 함께
Hezekiah Brown
회원 가입일: 02/11/21
6,277 평판
안내서 49개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 26
전체 시간: 1,493
