주요 콘텐츠로 건너뛰기
Dell Latitude E7470 Keyboard Replacement
필요한 것
  1. Dell Latitude E7470 Keyboard Replacement, RAM: 1 단계, 이미지 1/2 Dell Latitude E7470 Keyboard Replacement, RAM: 1 단계, 이미지 2/2
    • Grab the two clips beside the RAM stick and pull them outward. The RAM stick should release.
    • Remove the RAM from the device.
    • Repeat this for second RAM stick
  2. Dell Latitude E7470 Keyboard Replacement, Fan and Heatsink: 2 단계, 이미지 1/2 Dell Latitude E7470 Keyboard Replacement, Fan and Heatsink: 2 단계, 이미지 2/2
    • After opening the backcase of the computer, remove the screws using the Phillips #0 screwdriver.
    • Unplug and remove the wire from the socket.
  3. Dell Latitude E7470 Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the fan and heatsink from the laptop.
    • Make sure to wipe off the existing thermal paste from the CPU and heatsink with an alcohol-soaked pad and apply a new layer.
  4. Dell Latitude E7470 Keyboard Replacement, Battery: 4 단계, 이미지 1/1
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  5. Dell Latitude E7470 Keyboard Replacement: 5 단계, 이미지 1/2 Dell Latitude E7470 Keyboard Replacement: 5 단계, 이미지 2/2
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  6. Dell Latitude E7470 Keyboard Replacement: 6 단계, 이미지 1/1
    • Remove the battery from the laptop.
  7. Dell Latitude E7470 Keyboard Replacement, Motherboard: 7 단계, 이미지 1/3 Dell Latitude E7470 Keyboard Replacement, Motherboard: 7 단계, 이미지 2/3 Dell Latitude E7470 Keyboard Replacement, Motherboard: 7 단계, 이미지 3/3
    • Remove all the screws using a Phillips #0 screwdriver.
    • Disconnect all of the cables from the motherboard.
  8. Dell Latitude E7470 Keyboard Replacement: 8 단계, 이미지 1/1
    • Remove the motherboard from the laptop.
  9. Dell Latitude E7470 Keyboard Replacement, Keyboard: 9 단계, 이미지 1/3 Dell Latitude E7470 Keyboard Replacement, Keyboard: 9 단계, 이미지 2/3 Dell Latitude E7470 Keyboard Replacement, Keyboard: 9 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the seventeen 4 mm screws.
  10. Dell Latitude E7470 Keyboard Replacement: 10 단계, 이미지 1/2 Dell Latitude E7470 Keyboard Replacement: 10 단계, 이미지 2/2
    • Disconnect the four ribbon wires labeled by the red rectangles by pushing aside the metal release tab and gently pulling the ribbon wire.
  11. Dell Latitude E7470 Keyboard Replacement: 11 단계, 이미지 1/2 Dell Latitude E7470 Keyboard Replacement: 11 단계, 이미지 2/2
    • Remove the keyboard from the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Bo Zeng
회원 가입일: 10/01/19
385 평판
안내서 3개 작성하였습니다
댓글 5개
Very useful photos. Keyboard changed successfully. Thank you.
William Bate - 답글
Also was able to change keyboard successfully.
Will note that there are some screws noted for motherboard and keyboard that already removed in previous steps. Was confusing for a bit.
Rodney Schaffran - 답글
An interesting discovery - the keyboards for the UK and US versions are slightly different, and annoyingly don't fit.
Richard Holmes - 답글
However, an excellent guide - thank you for taking the time to compile it.
Richard Holmes - 답글
I have the E7470 without the pointer and the keyboard isn't backlit and it doesn't have the palm rest above the touchpad. I have found a backlit keyboard on eBay (unlike the keyboard in this tutorial) that looks identical to mine but only has 2 ribbons. I'm guessing one for the keyboard and for the backlight. My motherboard has a spare connector next to the main ribbon (here are the pics of my motherboard and the keyboard I'm referring to: https://www.dell.com/community/Latitude/... - the 2 pics at the bottom of the thread). The connector I'm referring to is the same as the one marked by the red square on the far right of the pic at Step 10 of this tutorial. Am I correct in assuming that this is the connector for the backlight?
BACVH - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 35
전체 시간: 5,460
