소개
If your device is still not working you may need to replace the motherboard. This replacement guide walks you through each step of how to safely remove and replace your Dell Latitude ST motherboard.
필요한 것
Remove the 3mm Phillips #0 screw from the SSD drive which is located above the speaker and to the left of the motherboard.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
