주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Dell Latitude X300 Keyboard Replacement
필요한 것
  1. Dell Latitude X300 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
  2. Dell Latitude X300 Keyboard Replacement: 2 단계, 이미지 1/2 Dell Latitude X300 Keyboard Replacement: 2 단계, 이미지 2/2
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  3. Dell Latitude X300 Keyboard Replacement: 3 단계, 이미지 1/1
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  4. Dell Latitude X300 Keyboard Replacement: 4 단계, 이미지 1/1
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  5. Dell Latitude X300 Keyboard Replacement: 5 단계, 이미지 1/1
    • Remove the flexible ribbon from ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
결론
Jacob Egorov
회원 가입일: 01/20/12
1 평판
안내서 1개 작성함
Cal Poly, Team 11-20, Maness Winter 2012 Cal Poly, Team 11-20, Maness Winter 2012 회원
CPSU-MANESS-W12S11G20
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,230
