주요 콘텐츠로 건너뛰기
Dell Latitude X300 Palm Rest/Track Pad Replacement
필요한 것
  1. Dell Latitude X300 Palm Rest/Track Pad Replacement, Battery: 1 단계, 이미지 1/1
    • Before removing the battery from the laptop, make sure the power is off.
    • Push both battery locking clips outward at the same time.
  2. Dell Latitude X300 Palm Rest/Track Pad Replacement: 2 단계, 이미지 1/1
    • Slide the battery out of the laptop.
  3. Dell Latitude X300 Palm Rest/Track Pad Replacement, Keyboard: 3 단계, 이미지 1/1
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  4. Dell Latitude X300 Palm Rest/Track Pad Replacement: 4 단계, 이미지 1/2 Dell Latitude X300 Palm Rest/Track Pad Replacement: 4 단계, 이미지 2/2
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  5. Dell Latitude X300 Palm Rest/Track Pad Replacement: 5 단계, 이미지 1/1
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  6. Dell Latitude X300 Palm Rest/Track Pad Replacement: 6 단계, 이미지 1/1
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  7. Dell Latitude X300 Palm Rest/Track Pad Replacement: 7 단계, 이미지 1/1
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
  8. Dell Latitude X300 Palm Rest/Track Pad Replacement, Palm Rest/Track Pad: 8 단계, 이미지 1/1
    • Position the laptop so that the bottom is facing upward.
    • Remove the three 4 mm Phillips #0 screws holding the bottom of the palm rest.
  9. Dell Latitude X300 Palm Rest/Track Pad Replacement: 9 단계, 이미지 1/1
    • Return the laptop to proper position and open the screen.
    • Remove the six 4 mm Phillips #0 screws holding in the palm rest.
  10. Dell Latitude X300 Palm Rest/Track Pad Replacement: 10 단계, 이미지 1/1
    • Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
    • The ribbon attached to the track is short and extremely delicate. Use care when moving the palm rest.
  11. Dell Latitude X300 Palm Rest/Track Pad Replacement: 11 단계, 이미지 1/1
    • Lift up on the small ZIF connector and remove the ribbon.
    • If the ribbon seems stuck, gently wiggle it to remove. Do not pull the ribbon with great force.
결론
Thomas Wong
회원 가입일: 01/20/12
23 평판
안내서 2개 작성하였습니다
Cal Poly, Team 11-20, Maness Winter 2012 Cal Poly, Team 11-20, Maness Winter 2012 회원
CPSU-MANESS-W12S11G20
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 871
