주요 콘텐츠로 건너뛰기
Dell Latitude X300 RAM Replacement
필요한 것
  1. Dell Latitude X300 RAM Replacement, RAM: 1 단계, 이미지 1/2 Dell Latitude X300 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Turn the laptop over so that the bottom is facing up.
    • Remove the two #0 3 mm screws holding the cover plate.
  2. Dell Latitude X300 RAM Replacement: 2 단계, 이미지 1/1
    • Push both metal retaining clips outward at the same time using your hands carefully.
    • If done correctly the memory should pop up at a 45 degree angle.
  3. Dell Latitude X300 RAM Replacement: 3 단계, 이미지 1/1
    • Gently pull the memory out of the retainer at the same 45 degree angle.
  4. Dell Latitude X300 RAM Replacement: 4 단계, 이미지 1/1
    • Insert the new memory at 45 degree angle.
  5. Dell Latitude X300 RAM Replacement: 5 단계, 이미지 1/1
    • Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
결론
To reassemble your device, reinstall cover plate with two #0 screws.
Thomas Wong
회원 가입일: 01/20/12
23 평판
안내서 2개 작성하였습니다
Cal Poly, Team 11-20, Maness Winter 2012 Cal Poly, Team 11-20, Maness Winter 2012 회원
CPSU-MANESS-W12S11G20
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 2,205
