이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the laptop over so that the bottom is facing up.
Remove the two #0 3 mm screws holding the cover plate.
Push both metal retaining clips outward at the same time using your hands carefully.
Gently pull the memory out of the retainer at the same 45 degree angle.
Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
