주요 콘텐츠로 건너뛰기
Dell Latitude X300 Screen Replacement
필요한 것
  1. Dell Latitude X300 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Make sure the Dell Latitude X300 power is off.
    • Remove the battery located on the bottom of the device by pushing in both clips.
  2. Dell Latitude X300 Screen Replacement: 2 단계, 이미지 1/2 Dell Latitude X300 Screen Replacement: 2 단계, 이미지 2/2
    • Remove rubber caps on each corner of the front screen with a pinch.
    • Remove the 4 mm screws located on the front screen of the laptop.
  3. Dell Latitude X300 Screen Replacement: 3 단계, 이미지 1/1
    • Carefully, remove the screen casing using either your hands or a proper tool.
    • The casing is very flimsy, so extreme care is required.
  4. Dell Latitude X300 Screen Replacement: 4 단계, 이미지 1/1
    • Remove the 4 mm screws on the bottom left and bottom right corner of the screen.
  5. Dell Latitude X300 Screen Replacement: 5 단계, 이미지 1/2 Dell Latitude X300 Screen Replacement: 5 단계, 이미지 2/2
    • Carefully lift the screen and place it on it's face.
    • Disconnect the wiring attached to the screen.
    • It is important not to damage this wire.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jacob
회원 가입일: 03/12/14
9 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014 회원
UMASSD-VIJAYBHASKAR-S14S6G1
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 730
