주요 콘텐츠로 건너뛰기
Dell OptiPlex 9010 CPU Fan Replacement
필요한 것
  1. Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: 1 단계, 이미지 1/3 Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: 1 단계, 이미지 2/3 Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: 1 단계, 이미지 3/3
    • Ensure the PC is physically unplugged before beginning any disassembly procedures!
    • Place the PC on a flat surface.
    • Turn the PC over so that the panel side faces upward.
  2. Dell OptiPlex 9010 CPU Fan Replacement: 2 단계, 이미지 1/3 Dell OptiPlex 9010 CPU Fan Replacement: 2 단계, 이미지 2/3 Dell OptiPlex 9010 CPU Fan Replacement: 2 단계, 이미지 3/3
    • Use your hand to lift the handle upward to access the hardware.
  3. Dell OptiPlex 9010 CPU Fan Replacement: 3 단계, 이미지 1/2 Dell OptiPlex 9010 CPU Fan Replacement: 3 단계, 이미지 2/2
    • Locate the CPU fan
    • Locate the fan header
  4. Dell OptiPlex 9010 CPU Fan Replacement: 4 단계, 이미지 1/3 Dell OptiPlex 9010 CPU Fan Replacement: 4 단계, 이미지 2/3 Dell OptiPlex 9010 CPU Fan Replacement: 4 단계, 이미지 3/3
    • Unplug the fan header by pressing the little button and pulling upward.
  5. Dell OptiPlex 9010 CPU Fan Replacement: 5 단계, 이미지 1/2 Dell OptiPlex 9010 CPU Fan Replacement: 5 단계, 이미지 2/2
    • Unscrew the 1.2 mm screw using a Phillips #1 screwdriver by turning it counterclockwise (left)
    • Repeat the second step for the other 3 screws
    • If necessary, apply downward pressure on the screwdriver while turning to ensure the screws are fully removed
  6. Dell OptiPlex 9010 CPU Fan Replacement: 6 단계, 이미지 1/3 Dell OptiPlex 9010 CPU Fan Replacement: 6 단계, 이미지 2/3 Dell OptiPlex 9010 CPU Fan Replacement: 6 단계, 이미지 3/3
    • After disconnecting the fan from the frame, carefully lift the fan up.
    • Be sure to store the screws safely, as they will be needed later on.
  7. Dell OptiPlex 9010 CPU Fan Replacement: 7 단계, 이미지 1/3 Dell OptiPlex 9010 CPU Fan Replacement: 7 단계, 이미지 2/3 Dell OptiPlex 9010 CPU Fan Replacement: 7 단계, 이미지 3/3
    • Take the fan you intend to insert into the computer.
    • Align the new fan over the four screws you previously removed.
    • Insert the new fan header into its socket.
  8. Dell OptiPlex 9010 CPU Fan Replacement: 8 단계, 이미지 1/3 Dell OptiPlex 9010 CPU Fan Replacement: 8 단계, 이미지 2/3 Dell OptiPlex 9010 CPU Fan Replacement: 8 단계, 이미지 3/3
    • Ensure the fan is correctly aligned with the four screw holes.
    • Place screws back in the holes
    • Tighten screws using the Phillips #1 screwdriver by turning it clockwise (right).
    • If needed, apply downward pressure on the screwdriver while turning to ensure the screws are securely tightened.
  9. Dell OptiPlex 9010 CPU Fan Replacement: 9 단계, 이미지 1/3 Dell OptiPlex 9010 CPU Fan Replacement: 9 단계, 이미지 2/3 Dell OptiPlex 9010 CPU Fan Replacement: 9 단계, 이미지 3/3
    • The replacement of the Dell Optiplex 9010 Fan has been complete!
    • Place the access panel back on to secure the inner hardware.
결론
You have successfully replaced the CPU Fan of your Dell Optiplex 9010!
다른 한 분이 해당 안내서를 완성하였습니다.
Abhiraj Khinda
회원 가입일: 09/13/23
196 평판
안내서 1개 작성함
York University, Team 1-16, O'Regan Summer 2023 York University, Team 1-16, O'Regan Summer 2023 회원
YORK-O'REGAN-SU23S1G16
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 40
전체 시간: 178
