소개
We are going to guide you through the steps to remove the current speaker and replace it with a new speaker.
필요한 것
Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
Remove the 5mm Philips #0 screw securing the speaker mounting bracket to the case.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
