주요 콘텐츠로 건너뛰기
Dell OptiPlex FX170 Memory Board Replacement
필요한 것
  1. Dell OptiPlex FX170 Memory Board Replacement, Case: 1 단계, 이미지 1/1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Dell OptiPlex FX170 Memory Board Replacement: 2 단계, 이미지 1/2 Dell OptiPlex FX170 Memory Board Replacement: 2 단계, 이미지 2/2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Dell OptiPlex FX170 Memory Board Replacement: 3 단계, 이미지 1/3 Dell OptiPlex FX170 Memory Board Replacement: 3 단계, 이미지 2/3 Dell OptiPlex FX170 Memory Board Replacement: 3 단계, 이미지 3/3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Dell OptiPlex FX170 Memory Board Replacement: 4 단계, 이미지 1/2 Dell OptiPlex FX170 Memory Board Replacement: 4 단계, 이미지 2/2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  5. Dell OptiPlex FX170 Memory Board Replacement, Memory Board: 5 단계, 이미지 1/1
    • Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
결론
Ashley Hansen
회원 가입일: 01/13/15
237 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 1,431
