주요 콘텐츠로 건너뛰기
Dell OptiPlex FX170 RAM Replacement
필요한 것
  1. Dell OptiPlex FX170 RAM  Replacement, Case: 1 단계, 이미지 1/1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Dell OptiPlex FX170 RAM  Replacement: 2 단계, 이미지 1/2 Dell OptiPlex FX170 RAM  Replacement: 2 단계, 이미지 2/2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Dell OptiPlex FX170 RAM  Replacement: 3 단계, 이미지 1/3 Dell OptiPlex FX170 RAM  Replacement: 3 단계, 이미지 2/3 Dell OptiPlex FX170 RAM  Replacement: 3 단계, 이미지 3/3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Dell OptiPlex FX170 RAM  Replacement: 4 단계, 이미지 1/2 Dell OptiPlex FX170 RAM  Replacement: 4 단계, 이미지 2/2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  5. Dell OptiPlex FX170 RAM  Replacement, RAM: 5 단계, 이미지 1/2 Dell OptiPlex FX170 RAM  Replacement, RAM: 5 단계, 이미지 2/2
    • Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
  6. Dell OptiPlex FX170 RAM  Replacement: 6 단계, 이미지 1/1
    • Lift and pull out the RAM.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ashley Hansen
회원 가입일: 01/13/15
237 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 13
전체 시간: 1,345
