주요 콘텐츠로 건너뛰기
Dell OptiPlex GX260 Case Replacement
필요한 것
  1. Dell OptiPlex GX260 Case Replacement, Case: 1 단계, 이미지 1/2 Dell OptiPlex GX260 Case Replacement, Case: 1 단계, 이미지 2/2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
    cool de faires des sites comme ca :)
    baptiste Prando - 답글
    Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
    sheila_jones - 답글
    I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
    Elvis 1357 - 답글
    Also, want to add another HD....but, there are no cables at all?
    Elvis 1357 - 답글
결론
To close the case, simply press it closed until you hear the tabs click into place.
다른 18명이 해당 안내서를 완성하였습니다.
Kevin Schapansky
회원 가입일: 10/05/10
1,457 평판
안내서 9개 작성하였습니다
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G48
4 회원들
안내서 27개 작성하였습니다
댓글 한 개
Thanks, couldn’t for the life of me figure out how to open the silly thing. :)
technojunkie_1999 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 30
전체 시간: 18,658
