주요 콘텐츠로 건너뛰기
  1. Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you. Push the  oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
결론
To close the case, simply press it closed until you hear the tabs click into place.
다른 16명이 해당 안내서를 완성하였습니다.
Kevin Schapansky
회원 가입일: 2010년 10월 05일
1,418 평판
안내서 9개 작성하였습니다
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G48
4 회원들
안내서 27개 작성하였습니다
Thanks, couldn’t for the life of me figure out how to open the silly thing. :)
technojunkie_1999 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 11
30일 전: 69
전체 시간: 17,042
