주요 콘텐츠로 건너뛰기
Dell OptiPlex GX260 Hard Drive Replacement
필요한 것
  1. Dell OptiPlex GX260 Hard Drive Replacement, Case: 1 단계, 이미지 1/2 Dell OptiPlex GX260 Hard Drive Replacement, Case: 1 단계, 이미지 2/2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/3 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: 2 단계, 이미지 2/3 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: 2 단계, 이미지 3/3
    • Identify the Hard Drive in the case.
    • If there is more than one hard drive installed the process is the same for each hard drive.
    • Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
    • Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
  3. Dell OptiPlex GX260 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Pinch the two green tabs inwards to release the hard drive and lift it out.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Kevin Schapansky
회원 가입일: 10/05/10
1,457 평판
안내서 9개 작성하였습니다
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G48
4 회원들
안내서 27개 작성하였습니다
댓글 한 개
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Also, want to add another HD....but, there are no cables at all?
Elvis 1357 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 31
전체 시간: 18,772
