필요한 것
Identify the Hard Drive in the case.
Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
Pinch the two green tabs inwards to release the hard drive and lift it out.
buenos dias como se llama las pieza de color verde que trai el disco duro que trai en los lados
다른 8명이 해당 안내서를 완성하였습니다.
댓글 한 개
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Also, want to add another HD....but, there are no cables at all?
Elvis 1357 - 답글
cool de faires des sites comme ca :)
baptiste Prando - 답글
Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
sheila_jones - 답글
Elvis 1357 - 답글
Elvis 1357 - 답글
