주요 콘텐츠로 건너뛰기
Dell OptiPlex GX260 Main Fan Replacement
필요한 것
  1. Dell OptiPlex GX260 Main Fan Replacement, Case: 1 단계, 이미지 1/2 Dell OptiPlex GX260 Main Fan Replacement, Case: 1 단계, 이미지 2/2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Main Fan Replacement, Main Fan: 2 단계, 이미지 1/2 Dell OptiPlex GX260 Main Fan Replacement, Main Fan: 2 단계, 이미지 2/2
    • Disconnect the fan cable from the motherboard.
  3. Dell OptiPlex GX260 Main Fan Replacement: 3 단계, 이미지 1/3 Dell OptiPlex GX260 Main Fan Replacement: 3 단계, 이미지 2/3 Dell OptiPlex GX260 Main Fan Replacement: 3 단계, 이미지 3/3
    • On the rear of the desktop, push the two circled black buttons straight in with a small pointed object while pulling up on the fan.
    • Once the fan is released, lift it straight up and out of the case.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Kevin Schapansky
회원 가입일: 10/05/10
1,457 평판
안내서 9개 작성하였습니다
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G48
4 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 7,971
