주요 콘텐츠로 건너뛰기
Dell OptiPlex GX260 RAM Replacement
  1. Dell OptiPlex GX260 RAM Replacement, Case: 1 단계, 이미지 1/2 Dell OptiPlex GX260 RAM Replacement, Case: 1 단계, 이미지 2/2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
    cool de faires des sites comme ca :)
    baptiste Prando - 답글
    Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
    sheila_jones - 답글
    I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
    Elvis 1357 - 답글
    Also, want to add another HD....but, there are no cables at all?
    Elvis 1357 - 답글
  2. Dell OptiPlex GX260 RAM Replacement, RAM: 2 단계, 이미지 1/2 Dell OptiPlex GX260 RAM Replacement, RAM: 2 단계, 이미지 2/2
    • Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
    tg beaufion travail
    Heinsenberg - 답글
    Albert reste polie
    Heinsenberg - 답글
    jvai tenculer baltringue va
    Heinsenberg - 답글
    Oh calmer vous les collégiens la!
    Momo - 답글
    zamaaaaaaaaan tu fait quoi la
    sisoko kirikou - 답글
    coco arrete tes blocus
    Coco tete du blocus -
    BENJUX ENTHE FLUX arret t’es conérie
    sisoko kirikou - 답글
    Sdk mes bébé la
    LaMereACoco - 답글
    c’est un ouff l’acteur
    Coco tete du blocus - 답글
    c’est un oufff Ritchie
    Abder.zamouk - 답글
결론
다른 11명이 해당 안내서를 완성하였습니다.
Kevin Schapansky
회원 가입일: 10/05/10
1,457 평판
안내서 9개 작성하였습니다
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G48
4 회원들
안내서 27개 작성하였습니다
댓글 5개
Rideau Cottage est construit par Stewart Taylor and Co., selon les plans de l'architecte ++Frederick Preston Rubidge++ ; le chantier commence en 1866 et se termine l'année suivante^^++[2]. Le coût de la construction s'est élevé à 5 000 ++$CA++^^++[1++]. Bien qu'il ait été prévu dans les premiers temps pour servir de résidence au ++secrétaire du gouverneur général++, le cottage est aussi utilisé par la suite comme résidence officielle pour les dignitaires en visite^^++[3^^].
Le premier agrandissement de Rideau Cottage a lieu en 1872 avec l'ajout d'un second étage et d'une ++véranda++ selon les plans de ++Thomas Seaton Scott++, architecte en chef de ++Travaux publics Canada++. En 1905, une annexe est ajoutée à l'arrière, principalement pour agrandir la cuisine. En 1933, une aile de deux étages est ajoutée au côté nord dans le but d'agrandir la salle à manger. Un porche grillagé et un garage contigu sont ajoutés par la suite. En 1954-1955 la véranda est remplacée par un ++porche++ d'inspiration classique^^++[2++^^].
antouibne - 답글
Astier RPZ hein
Momo - 답글
vachement bien ♥
Scooby-Doo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 12
전체 시간: 10,706
