주요 콘텐츠로 건너뛰기
Dell Optiplex 745 Small Form Factor Audio Components Replacement
필요한 것
  1. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: 1 단계, 이미지 1/2 Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: 1 단계, 이미지 2/2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Audio Components Replacement: 2 단계, 이미지 1/2 Dell Optiplex 745 Small Form Factor Audio Components Replacement: 2 단계, 이미지 2/2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Front Audio Panel: 3 단계, 이미지 1/1
    • Disconnect the cable attached to the audio panel by gently pulling the head of the cable away from the port.
    • When creating this guide a cable was absent, in the picture you will find where that cable would be connected.
  4. Dell Optiplex 745 Small Form Factor Audio Components Replacement: 4 단계, 이미지 1/1
    • Using a Phillips #2 screw driver, unscrew the 9.5 mm screw that holds the audio panel in place.
  5. Dell Optiplex 745 Small Form Factor Audio Components Replacement: 5 단계, 이미지 1/2 Dell Optiplex 745 Small Form Factor Audio Components Replacement: 5 단계, 이미지 2/2
    • Carefully grasp the audio panel from the sides, pull it back and out of it's slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeremy Nicholas
회원 가입일: 10/09/17
228 평판
안내서 2개 작성하였습니다
USF Tampa, Team S5-G5, Walkup Fall 2017 USF Tampa, Team S5-G5, Walkup Fall 2017 회원
USFT-WALKUP-F17S5G5
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 19
전체 시간: 1,155
