주요 콘텐츠로 건너뛰기
Dell Optiplex 745 Small Form Factor Graphics Card Replacement
  1. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement, Graphics Card: 1 단계, 이미지 1/3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement, Graphics Card: 1 단계, 이미지 2/3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement, Graphics Card: 1 단계, 이미지 3/3
    • Pull the tab on the cover to release the lid.
    • Remove the cover to expose the computer.
  2. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: 2 단계, 이미지 1/3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: 2 단계, 이미지 2/3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: 2 단계, 이미지 3/3
    • The graphics card has a fan built into it and is fasten by two blue clips.
    • Pull up the top blue clip that is above the graphics card while holding the graphics card in place.
  3. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: 3 단계, 이미지 1/3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: 3 단계, 이미지 2/3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: 3 단계, 이미지 3/3
    • Below the graphics card, there is a second clip that holds the card in place.
    • With one hand, pull back the clip while lifting the graphics card with the other.
  4. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: 4 단계, 이미지 1/1
    • Remove the graphics card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Daviel Almonte
회원 가입일: 10/03/17
155 평판
안내서 1개 작성함
USF Tampa, Team S5-G5, Walkup Fall 2017 USF Tampa, Team S5-G5, Walkup Fall 2017 회원
USFT-WALKUP-F17S5G5
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
Graphic card modal no please
Mans Manshion - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 37
전체 시간: 2,430
