주요 콘텐츠로 건너뛰기
Dell Optiplex 745 Small Form Factor Hard Drive Replacement
  1. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Opening the case: 1 단계, 이미지 2개 중 1개 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Opening the case: 1 단계, 이미지 2개 중 2개
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Dell Optiplex 745 Small Form Factor Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Disconnecting the cables: 3 단계, 이미지 2개 중 1개 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Disconnecting the cables: 3 단계, 이미지 2개 중 2개
    • Pull out both sets of cables from the side of the optical drive.
    • Both cables are plugged into the drive right next to each other.
  4. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Removing the optical drive: 4 단계, 이미지 2개 중 1개 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Removing the optical drive: 4 단계, 이미지 2개 중 2개
    • Pull the tab up holding the optical drive in place.
    • Slide the optical drive out.
  5. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the tray under the optical drive: 5 단계, 이미지 3개 중 1개 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the tray under the optical drive: 5 단계, 이미지 3개 중 2개 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the tray under the optical drive: 5 단계, 이미지 3개 중 3개
    • Rotate the computer 180 degrees.
    • Pull the metal tab up.
    • Pull the tray away from the case.
  6. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the hard drive case: 6 단계, 이미지 3개 중 1개 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the hard drive case: 6 단계, 이미지 3개 중 2개 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the hard drive case: 6 단계, 이미지 3개 중 3개
    • Pinch the 2 small blue tabs towards each other.
    • Push the large blue tab into the hard drive and push the hard drive away from the tower wall.
    • Lift the hard drive from the case after it comes loose.
  7. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the wires: 7 단계, 이미지 2개 중 1개 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the wires: 7 단계, 이미지 2개 중 2개
    • Pull out both bundles of wires connected to the hard drive.
    • Flip the hard drive so that the blue case is facing down, and the marked tabs are facing toward you.
  8. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Separate the hard drive and case.: 8 단계, 이미지 3개 중 1개 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Separate the hard drive and case.: 8 단계, 이미지 3개 중 2개 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Separate the hard drive and case.: 8 단계, 이미지 3개 중 3개
    • Pull the 2 blue tabs away from the hard drive and then pull the hard drive case down.
결론
다른 19명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Rebecca Harrison
회원 가입일: 09/29/14
524 평판
안내서 1개를 작성함
Cal Poly, Team 13-10, Forte Fall 2014 Cal Poly, Team 13-10, Forte Fall 2014 회원
CPSU-FORTE-F14S13G10
6 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 52
전체 시간: 10,023
