주요 콘텐츠로 건너뛰기
Dell Optiplex 745 Small Form Factor Motherboard Replacement
필요한 것
  1. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: 1 단계, 이미지 1/2 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: 1 단계, 이미지 2/2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 2 단계, 이미지 1/2 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 2 단계, 이미지 2/2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: 3 단계, 이미지 1/3 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: 3 단계, 이미지 2/3 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: 3 단계, 이미지 3/3
    • Disconnect all of the cords that are connected to the motherboard.
    • Press in the lever on the side of the male end, and then pull out.
    • Pull cord straight out.
    • Disconnect the front plate (USB and audio output) from the motherboard.
    • Some of the cords in the pictures are missing due to the condition of our device when creating this guide.
  4. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 4 단계, 이미지 1/3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 4 단계, 이미지 2/3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 4 단계, 이미지 3/3
    • Remove the graphics card.
    • Lift the blue latch on the fat end of the graphics card.
    • Pull the blue lever on the skinny end of the graphics card toward the power supply.
    • Pull out one end of the card at a time.
  5. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 5 단계, 이미지 1/3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 5 단계, 이미지 2/3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the heat sink.
    • Unscrew the (2) two screws using a Phillips #2 screwdriver and lift out the heat sink.
  6. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 6 단계, 이미지 1/3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 6 단계, 이미지 2/3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 6 단계, 이미지 3/3
    • Remove the (5) five 6mm Phillips #2 screws from the motherboard.
    • Remove the (2) two 17mm Phillips #2 screws from the mount for the heat sink.
  7. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 7 단계, 이미지 1/3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 7 단계, 이미지 2/3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 7 단계, 이미지 3/3
    • Remove the back plate by lifting straight out by the blue latch that secures the graphics card.
    • Pull the end of the motherboard closest to the back of the computer away from the static back plate.
    • Lift this end away and out of the case.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Alexander Rosner
회원 가입일: 10/03/17
291 평판
안내서 1개 작성함
USF Tampa, Team S5-G5, Walkup Fall 2017 USF Tampa, Team S5-G5, Walkup Fall 2017 회원
USFT-WALKUP-F17S5G5
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,718
