주요 콘텐츠로 건너뛰기
Dell Optiplex 745 Small Form Factor Optical Drive Replacement
  1. Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Opening the case: 1 단계, 이미지 1/2 Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Opening the case: 1 단계, 이미지 2/2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Optical Drive Replacement: 2 단계, 이미지 1/2 Dell Optiplex 745 Small Form Factor Optical Drive Replacement: 2 단계, 이미지 2/2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Disconnecting the cables: 3 단계, 이미지 1/2 Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Disconnecting the cables: 3 단계, 이미지 2/2
    • Pull out both sets of cables from the side of the optical drive.
    • Both cables are plugged into the drive right next to each other.
  4. Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Removing the optical drive: 4 단계, 이미지 1/2 Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Removing the optical drive: 4 단계, 이미지 2/2
    • Pull the tab up holding the optical drive in place.
    • Slide the optical drive out.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Tyler Whalen
회원 가입일: 09/29/14
835 평판
안내서 3개 작성하였습니다
Cal Poly, Team 13-10, Forte Fall 2014 Cal Poly, Team 13-10, Forte Fall 2014 회원
CPSU-FORTE-F14S13G10
6 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,962
