소개
This guide will help you replace the power supply.
필요한 것
Identify the power supply.
Remove the two 9.5 mm Phillips screws on the outside of the case.
Grab the plastic casing and pull out the bundle of cables from the side of the power supply unit.
Push the power supply from the back and lift from the front.
Lift the power supply out of the case.
거의 끝나갑니다!
결론
다른 16명이 해당 안내서를 완성하였습니다.
