주요 콘텐츠로 건너뛰기
Dell Optiplex 745 Small Form Factor RAM Replacement
  1. Dell Optiplex 745 Small Form Factor RAM Replacement, Opening the case: 1 단계, 이미지 2개 중 1개 Dell Optiplex 745 Small Form Factor RAM Replacement, Opening the case: 1 단계, 이미지 2개 중 2개
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor RAM Replacement: 2 단계, 이미지 2개 중 1개 Dell Optiplex 745 Small Form Factor RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor RAM Replacement, Disconnecting the cables: 3 단계, 이미지 2개 중 1개 Dell Optiplex 745 Small Form Factor RAM Replacement, Disconnecting the cables: 3 단계, 이미지 2개 중 2개
    • Pull out both sets of cables from the side of the optical drive.
    • Both cables are plugged into the drive right next to each other.
  4. Dell Optiplex 745 Small Form Factor RAM Replacement, Removing the optical drive: 4 단계, 이미지 2개 중 1개 Dell Optiplex 745 Small Form Factor RAM Replacement, Removing the optical drive: 4 단계, 이미지 2개 중 2개
    • Pull the tab up holding the optical drive in place.
    • Slide the optical drive out.
  5. Dell Optiplex 745 Small Form Factor RAM Replacement, Unlocking the RAM stick from the motherboard: 5 단계, 이미지 2개 중 1개 Dell Optiplex 745 Small Form Factor RAM Replacement, Unlocking the RAM stick from the motherboard: 5 단계, 이미지 2개 중 2개
    • Press down on the white tabs on both sides of the RAM stick until the RAM stick pops up.
  6. Dell Optiplex 745 Small Form Factor RAM Replacement, Lifting the RAM stick out of the case: 6 단계, 이미지 1개 중 1개
    • Gently lift the RAM stick up and out of the case.
    • When inserting a RAM stick, press firmly down into the slot until the white tabs lock into both sides of the stick.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brandon Cooper
회원 가입일: 09/28/14
486 평판
안내서 1개를 작성함
Cal Poly, Team 13-10, Forte Fall 2014 Cal Poly, Team 13-10, Forte Fall 2014 회원
CPSU-FORTE-F14S13G10
6 회원들
안내서 12개를 작성함
1가이드 댓글
Dell master. I'm going to be the best repair pro on this side of the south side.
fixitbrosmsus - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 16
전체 시간: 1,960
