주요 콘텐츠로 건너뛰기
Dell Optiplex 745 Ultra Small Form Factor CPU Replacement
필요한 것
  1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, Side Panel: 1 단계, 이미지 1/1
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 2 단계, 이미지 1/1
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 3 단계, 이미지 1/1
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: 4 단계, 이미지 1/2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: 4 단계, 이미지 2/2
    • Remove the blue shield by sliding it straight upwards.
  5. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 5 단계, 이미지 1/3 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 5 단계, 이미지 2/3 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 5 단계, 이미지 3/3
    • Pull back on the tab nearest to the front case fan.
    • Slide the CPU heat sink from under the clip and pull upward.
    • You may need to twist the CPU heat sink side to side to free it from the thermal paste.
  6. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: 6 단계, 이미지 1/2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: 6 단계, 이미지 2/2
    • Ground yourself before removing any internal components.
    • Push release lever down slightly and away from CPU.
  7. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 7 단계, 이미지 1/2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 7 단계, 이미지 2/2
    • Lift and rotate processor cover off of CPU.
    • Processor cover will remain attached.
  8. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 8 단계, 이미지 1/1
    • Using two fingers holding the sides, lift the CPU from the socket.
    • Do not touch the underside of the CPU or any of the pins.
    • When replacing the CPU, do not use excessive force.
    • Ensure to use the alignment-notches on the new CPU, when replacing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
donnavon
회원 가입일: 09/02/14
707 평판
안내서 7개 작성하였습니다
Pasco Hernando, Team 1-1, Prince Fall 2014 Pasco Hernando, Team 1-1, Prince Fall 2014 회원
PHSC-PRINCE-F14S1G1
11 회원들
안내서 14개 작성하였습니다
댓글 한 개
What Cpu does it use?
Jazelle Estrada - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 2,149
