주요 콘텐츠로 건너뛰기
Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement
  1. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement, Side Panel: 1 단계, 이미지 1개 중 1개
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 1개 Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 2개
    • Ground yourself to avoid static from damaging any components. Either use a wrist strap and antistatic mat, or touch the metal computer case every few minutes.
    • Find the power and data cables connected to the hard drive, press down on the metal tab and carefully remove them.
  5. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the blue tabs shown on the left and right of the hard disk drive
    • Squeeze both tabs and slide the hard disk drive towards you, then lift the drive out of the cage.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
donnavon
회원 가입일: 09/02/14
713 평판
안내서 7개를 작성함
Pasco Hernando, Team 1-1, Prince Fall 2014 Pasco Hernando, Team 1-1, Prince Fall 2014 회원
PHSC-PRINCE-F14S1G1
11 회원들
안내서 14개를 작성함
1가이드 댓글
I need of one this..+966551432137 WhatsApp
Luke Zoie - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 1,820
