주요 콘텐츠로 건너뛰기
Dell Optiplex 745 Ultra Small Form Factor RAM Replacement
필요한 것
  1. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement, Side Panel: 1 단계, 이미지 1/1
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement: 2 단계, 이미지 1/1
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement: 3 단계, 이미지 1/1
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement, Hard Drive: 4 단계, 이미지 1/2 Dell Optiplex 745 Ultra Small Form Factor RAM Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Ground yourself to avoid static from damaging any components. Either use a wrist strap and antistatic mat, or touch the metal computer case every few minutes.
    • Find the power and data cables connected to the hard drive, press down on the metal tab and carefully remove them.
  5. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement: 5 단계, 이미지 1/2 Dell Optiplex 745 Ultra Small Form Factor RAM Replacement: 5 단계, 이미지 2/2
    • Locate the blue tabs shown on the left and right of the hard disk drive
    • Squeeze both tabs and slide the hard disk drive towards you, then lift the drive out of the cage.
  6. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement, RAM: 6 단계, 이미지 1/1
    • Press down on the two white tabs on either side of the memory module; the RAM will pop out.
    • Be sure you are grounded to avoid electrostatic discharge, and place your memory modules in an anti-static bag.
    • Make sure the notch in the RAM lines up with the notch in the slot. It should enter the slot with minimal force. If it does not enter the slot, check that you have the RAM lined up properly.
결론
donnavon
회원 가입일: 09/02/14
707 평판
안내서 7개 작성하였습니다
Pasco Hernando, Team 1-1, Prince Fall 2014 Pasco Hernando, Team 1-1, Prince Fall 2014 회원
PHSC-PRINCE-F14S1G1
11 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 11
전체 시간: 1,780
