이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The CMOS battery maintains the time, date, hard disk and other configuration settings in the CMOS memory. When your CMOS battery dies, your system settings will be lost.
필요한 것
Power down your PC and remove the power cord from the back.
With the computer standing upright, firmly pull on the tab at the back of the computer.
When the side panel pops free, gently pull the panel away from the computer.
Insert a tool beside the battery and gently pry the battery out.
To reassemble your device, follow these instructions in reverse order. Make sure you place the battery with the flat (positive) side facing up.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 2개
Thank you for this. It gave me the courage to do the job, and told me how. I'm very, very grateful.
