주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Optiplex GX620 CPU Replacement
필요한 것
  1. Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: 1 단계, 이미지 2개 중 1개 Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: 1 단계, 이미지 2개 중 2개
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 CPU Replacement: 2 단계, 이미지 2개 중 1개 Dell Optiplex GX620 CPU Replacement: 2 단계, 이미지 2개 중 2개
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 CPU Replacement, Dell Optiplex GX620 Side Panel Disassembly: 3 단계, 이미지 1개 중 1개
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: 4 단계, 이미지 3개 중 1개 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: 4 단계, 이미지 3개 중 2개 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: 4 단계, 이미지 3개 중 3개
    • Move the cables out of your way.
    • SATA Power
    • SATA Data
  5. Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: 5 단계, 이미지 3개 중 1개 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: 5 단계, 이미지 3개 중 2개 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: 5 단계, 이미지 3개 중 3개
    • Unplug the power cable
    • Unplug the data cable
  6. Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: 6 단계, 이미지 2개 중 1개 Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: 6 단계, 이미지 2개 중 2개
    • Unplug the fan that is on the motherboard.
  7. Dell Optiplex GX620 CPU Replacement: 7 단계, 이미지 2개 중 1개 Dell Optiplex GX620 CPU Replacement: 7 단계, 이미지 2개 중 2개
    • There is two Phillips #2 screws that need to be removed.
    • The two screws have springs that keep them there.
  8. Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: 8 단계, 이미지 3개 중 1개 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: 8 단계, 이미지 3개 중 2개 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: 8 단계, 이미지 3개 중 3개
    • Lift the heat sink.
  9. Dell Optiplex GX620 CPU Replacement, CPU removal.: 9 단계, 이미지 3개 중 1개 Dell Optiplex GX620 CPU Replacement, CPU removal.: 9 단계, 이미지 3개 중 2개 Dell Optiplex GX620 CPU Replacement, CPU removal.: 9 단계, 이미지 3개 중 3개
    • Push and release tap on it. And then take the CPU out.
    • Remember to put new thermal paste on the CPU.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Padraic Hoselton
회원 가입일: 08/22/17
4,369 평판
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 21
지난 30일: 43
전체 시간: 2,855
