주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Optiplex GX620 Fan Replacement
필요한 것
  1. Dell Optiplex GX620 Fan Replacement, How to unplug and discharge before repair: 1 단계, 이미지 2개 중 1개 Dell Optiplex GX620 Fan Replacement, How to unplug and discharge before repair: 1 단계, 이미지 2개 중 2개
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Fan Replacement: 2 단계, 이미지 2개 중 1개 Dell Optiplex GX620 Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Fan Replacement, Dell Optiplex GX620 Side Panel Disassembly: 3 단계, 이미지 1개 중 1개
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Fan Replacement, Unplug your Hard drive.: 4 단계, 이미지 3개 중 1개 Dell Optiplex GX620 Fan Replacement, Unplug your Hard drive.: 4 단계, 이미지 3개 중 2개 Dell Optiplex GX620 Fan Replacement, Unplug your Hard drive.: 4 단계, 이미지 3개 중 3개
    • Unplug your hard drives power and data cables.
  5. Dell Optiplex GX620 Fan Replacement, Unplug floppy drive.: 5 단계, 이미지 3개 중 1개 Dell Optiplex GX620 Fan Replacement, Unplug floppy drive.: 5 단계, 이미지 3개 중 2개 Dell Optiplex GX620 Fan Replacement, Unplug floppy drive.: 5 단계, 이미지 3개 중 3개
    • Unplug the power and data cables.
  6. Dell Optiplex GX620 Fan Replacement, Unplug the fan.: 6 단계, 이미지 2개 중 1개 Dell Optiplex GX620 Fan Replacement, Unplug the fan.: 6 단계, 이미지 2개 중 2개
    • Unplug the fan.
  7. Dell Optiplex GX620 Fan Replacement: 7 단계, 이미지 2개 중 1개 Dell Optiplex GX620 Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the two Phillips #2 screws.
  8. Dell Optiplex GX620 Fan Replacement, Remove the heat sink.: 8 단계, 이미지 3개 중 1개 Dell Optiplex GX620 Fan Replacement, Remove the heat sink.: 8 단계, 이미지 3개 중 2개 Dell Optiplex GX620 Fan Replacement, Remove the heat sink.: 8 단계, 이미지 3개 중 3개
    • Pull the heat sink up.
  9. Dell Optiplex GX620 Fan Replacement: 9 단계, 이미지 3개 중 1개 Dell Optiplex GX620 Fan Replacement: 9 단계, 이미지 3개 중 2개 Dell Optiplex GX620 Fan Replacement: 9 단계, 이미지 3개 중 3개
    • Pull the two tabs and pull it out.
    • This needs a lot of force to take it off.
  10. Dell Optiplex GX620 Fan Replacement, Take the fan out of its enclosure.: 10 단계, 이미지 3개 중 1개 Dell Optiplex GX620 Fan Replacement, Take the fan out of its enclosure.: 10 단계, 이미지 3개 중 2개 Dell Optiplex GX620 Fan Replacement, Take the fan out of its enclosure.: 10 단계, 이미지 3개 중 3개
    • To take the fan out you have to pull the two tabs and pull the fan out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Padraic Hoselton
회원 가입일: 08/22/17
4,369 평판
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 53
전체 시간: 2,709
