주요 콘텐츠로 건너뛰기
Dell Optiplex GX620 Motherboard Replacement
필요한 것
  1. Dell Optiplex GX620 Motherboard  Replacement, How to unplug and discharge before repair: 1 단계, 이미지 1/2 Dell Optiplex GX620 Motherboard  Replacement, How to unplug and discharge before repair: 1 단계, 이미지 2/2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Motherboard  Replacement: 2 단계, 이미지 1/2 Dell Optiplex GX620 Motherboard  Replacement: 2 단계, 이미지 2/2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Motherboard  Replacement, Dell Optiplex GX620 Side Panel Disassembly: 3 단계, 이미지 1/1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Motherboard  Replacement, Now unplug your hard drives power and data cables.: 4 단계, 이미지 1/3 Dell Optiplex GX620 Motherboard  Replacement, Now unplug your hard drives power and data cables.: 4 단계, 이미지 2/3 Dell Optiplex GX620 Motherboard  Replacement, Now unplug your hard drives power and data cables.: 4 단계, 이미지 3/3
    • Move the cables out of your way.
    • SATA Power
    • SATA Data
  5. Dell Optiplex GX620 Motherboard  Replacement, Unplug your floppy drive on the motherboard and the drive.: 5 단계, 이미지 1/3 Dell Optiplex GX620 Motherboard  Replacement, Unplug your floppy drive on the motherboard and the drive.: 5 단계, 이미지 2/3 Dell Optiplex GX620 Motherboard  Replacement, Unplug your floppy drive on the motherboard and the drive.: 5 단계, 이미지 3/3
    • Unplug the power cable
    • Unplug the data cable
  6. Dell Optiplex GX620 Motherboard  Replacement, Disconnect CPU fan.: 6 단계, 이미지 1/2 Dell Optiplex GX620 Motherboard  Replacement, Disconnect CPU fan.: 6 단계, 이미지 2/2
    • Unplug the fan that is on the motherboard.
  7. Dell Optiplex GX620 Motherboard  Replacement: 7 단계, 이미지 1/2 Dell Optiplex GX620 Motherboard  Replacement: 7 단계, 이미지 2/2
    • There is two Phillips #2 screws that need to be removed.
    • The two screws have springs that keep them there.
  8. Dell Optiplex GX620 Motherboard  Replacement, New it’s time to remove the  heat sink.: 8 단계, 이미지 1/3 Dell Optiplex GX620 Motherboard  Replacement, New it’s time to remove the  heat sink.: 8 단계, 이미지 2/3 Dell Optiplex GX620 Motherboard  Replacement, New it’s time to remove the  heat sink.: 8 단계, 이미지 3/3
    • Lift the heat sink.
  9. Dell Optiplex GX620 Motherboard  Replacement, CPU removal.: 9 단계, 이미지 1/3 Dell Optiplex GX620 Motherboard  Replacement, CPU removal.: 9 단계, 이미지 2/3 Dell Optiplex GX620 Motherboard  Replacement, CPU removal.: 9 단계, 이미지 3/3
    • Push and release tap on it. And then take the CPU out.
    • Remember to put new thermal paste on the CPU.
  10. Dell Optiplex GX620 Motherboard  Replacement, Remove the ram: 10 단계, 이미지 1/2 Dell Optiplex GX620 Motherboard  Replacement, Remove the ram: 10 단계, 이미지 2/2
    • Push the tabs down.
    • Pull the cards out.
  11. Dell Optiplex GX620 Motherboard  Replacement, Remove the DVD cable: 11 단계, 이미지 1/3 Dell Optiplex GX620 Motherboard  Replacement, Remove the DVD cable: 11 단계, 이미지 2/3 Dell Optiplex GX620 Motherboard  Replacement, Remove the DVD cable: 11 단계, 이미지 3/3
    • Pull the two cables from the DVD drive off.
  12. Dell Optiplex GX620 Motherboard  Replacement: 12 단계, 이미지 1/2 Dell Optiplex GX620 Motherboard  Replacement: 12 단계, 이미지 2/2
    • Pull the power cable from the DVD drive off.
  13. Dell Optiplex GX620 Motherboard  Replacement, Remove the CPU power: 13 단계, 이미지 1/1
    • Pull the CPU power cable off.
  14. Dell Optiplex GX620 Motherboard  Replacement, Remove the three cables: 14 단계, 이미지 1/2 Dell Optiplex GX620 Motherboard  Replacement, Remove the three cables: 14 단계, 이미지 2/2
    • Pull the three cables off.
  15. Dell Optiplex GX620 Motherboard  Replacement, Remove the graphics card: 15 단계, 이미지 1/3 Dell Optiplex GX620 Motherboard  Replacement, Remove the graphics card: 15 단계, 이미지 2/3 Dell Optiplex GX620 Motherboard  Replacement, Remove the graphics card: 15 단계, 이미지 3/3
    • Push the tab to releases the latch.
    • Push the tab and pull the graphics card out.
  16. Dell Optiplex GX620 Motherboard  Replacement, Remove the motherboard screws: 16 단계, 이미지 1/2 Dell Optiplex GX620 Motherboard  Replacement, Remove the motherboard screws: 16 단계, 이미지 2/2
    • Remove the six Philips #2 screws.
    • Remove the two green Philips #2 screws.
  17. Dell Optiplex GX620 Motherboard  Replacement, Remove the motherboard: 17 단계, 이미지 1/3 Dell Optiplex GX620 Motherboard  Replacement, Remove the motherboard: 17 단계, 이미지 2/3 Dell Optiplex GX620 Motherboard  Replacement, Remove the motherboard: 17 단계, 이미지 3/3
    • Gently pull the motherboard out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Padraic Hoselton
회원 가입일: 08/22/17
4,171 평판
안내서 12개 작성하였습니다
Master Techs Master Techs 회원
Community
315 회원들
안내서 1,326개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 25
전체 시간: 2,890
