소개
This PCI network adapter enables users to connect to the internet typically though an Ethernet cable. You will not be able to obtain a connection if this device is faulty.
Power down your PC and remove the power cord from the back.
With the computer standing upright, firmly pull on the tab at the back of the computer.
When the side panel pops free, gently pull the panel away from the computer.
Gently push the release tab on the card retention latch from the inside to pivot the latch open. The latch will remain in the open position
With your free hand, gently squeeze the sides of the card. Pull upwards to release it from the tab slots that hold it in place.
다른 2명이 해당 안내서를 완성하였습니다.
