주요 콘텐츠로 건너뛰기
Dell Optiplex GX620 Power Supply Replacement
필요한 것
  1. Dell Optiplex GX620 Power Supply Replacement, How to unplug and discharge before repair: 1 단계, 이미지 1/2 Dell Optiplex GX620 Power Supply Replacement, How to unplug and discharge before repair: 1 단계, 이미지 2/2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Power Supply Replacement: 2 단계, 이미지 1/2 Dell Optiplex GX620 Power Supply Replacement: 2 단계, 이미지 2/2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Power Supply Replacement, Dell Optiplex GX620 Side Panel Disassembly: 3 단계, 이미지 1/1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: 4 단계, 이미지 1/3 Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: 4 단계, 이미지 2/3 Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: 4 단계, 이미지 3/3
    • Gently disconnect the power cables from the motherboard and drives.
  5. Dell Optiplex GX620 Power Supply Replacement, Remove the screws: 5 단계, 이미지 1/1
    • Remove the four screws that attach the power supply on the back of the chassis.
    • Do not remove any screws that are not highlighted in red.
  6. Dell Optiplex GX620 Power Supply Replacement, Press the release button: 6 단계, 이미지 1/1
    • Press the blue release button. This is located on the floor of the computer chassis right in front of the power supply.
  7. Dell Optiplex GX620 Power Supply Replacement, Remove the power supply: 7 단계, 이미지 1/1
    • Remove the unconnected power supply by sliding it towards the front of the computer. Next, lift it up out of the chassis.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Kristina
회원 가입일: 09/03/14
198 평판
안내서 7개 작성하였습니다
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014 회원
PHSC-PRINCE-F14S5G1
10 회원들
안내서 15개 작성하였습니다
댓글 3개
Thanks, I followed the instructions, the replacement of the power supply unit was more simple than I expected
George
geotech78 - 답글
i replaced that but not repair this
Muhammad Qasim - 답글
At post Madasanal TQ disk bijapur
sidaray - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 42
전체 시간: 7,028
