주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
To access all other parts, you must first remove the cover.
  1. Power down your PC and remove the power cord from the back. Power down your PC and remove the power cord from the back.
    • Power down your PC and remove the power cord from the back.
  2. Press and hold the power button for about 10 seconds, then release. This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. With the computer standing upright, firmly pull on the tab at the back of the computer.
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Kristina
회원 가입일: 2014년 09월 03일
168 평판
안내서 7개 작성하였습니다
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014 회원
PHSC-PRINCE-F14S5G1
10 회원들
안내서 15개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 93
전체 시간: 6,400
