주요 콘텐츠로 건너뛰기
Dell Optiplex SX280 Battery Replacement
필요한 것
  1. Dell Optiplex SX280 Battery Replacement, Panel Cover: 1 단계, 이미지 1/1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Battery Replacement: 2 단계, 이미지 1/2 Dell Optiplex SX280 Battery Replacement: 2 단계, 이미지 2/2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Battery Replacement: 3 단계, 이미지 1/2 Dell Optiplex SX280 Battery Replacement: 3 단계, 이미지 2/2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Battery Replacement, Hard Drive: 4 단계, 이미지 1/2 Dell Optiplex SX280 Battery Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Dell Optiplex SX280 Battery Replacement: 5 단계, 이미지 1/2 Dell Optiplex SX280 Battery Replacement: 5 단계, 이미지 2/2
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Dell Optiplex SX280 Battery Replacement: 6 단계, 이미지 1/1
    • Squeeze the release tabs on either side of the hard drive.
  7. Dell Optiplex SX280 Battery Replacement: 7 단계, 이미지 1/2 Dell Optiplex SX280 Battery Replacement: 7 단계, 이미지 2/2
    • Slide the Hard Drive out while squeezing the tabs.
  8. Dell Optiplex SX280 Battery Replacement, Battery: 8 단계, 이미지 1/1
    • Under the hard drive, there is a circular, silver battery connected to the motherboard.
    • Use a spudger to gently pry the battery from the motherboard.
  9. Dell Optiplex SX280 Battery Replacement: 9 단계, 이미지 1/1
    • Lift the battery out of the motherboard.
  10. Dell Optiplex SX280 Battery Replacement: 10 단계, 이미지 1/3 Dell Optiplex SX280 Battery Replacement: 10 단계, 이미지 2/3 Dell Optiplex SX280 Battery Replacement: 10 단계, 이미지 3/3
    • Upon replacement, simply push the battery into the motherboard.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Tom
회원 가입일: 10/04/10
841 평판
안내서 7개 작성하였습니다
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 회원
CPSU-MANESS-F10S22G4
4 회원들
안내서 26개 작성하였습니다
댓글 한 개
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
neverts “itchytastyurr” ennud - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 11,764
