주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Replace the Dead Battery on the Motherboard
부품
지정된 부품이 없습니다.
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Unplug the blue cable that connects the hard drive to the motherboard. Unplug the blue cable that connects the hard drive to the motherboard.
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  6. Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view). Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  7. Squeeze the release tabs on either side of the hard drive.
    • Squeeze the release tabs on either side of the hard drive.
  8. Slide the Hard Drive out while squeezing the tabs. Slide the Hard Drive out while squeezing the tabs.
    • Slide the Hard Drive out while squeezing the tabs.
  9. Under the hard drive, there is a circular, silver battery connected to the motherboard.
    • Under the hard drive, there is a circular, silver battery connected to the motherboard.
    • Use a spudger to gently pry the battery from the motherboard.
  10. Lift the battery out of the motherboard.
    • Lift the battery out of the motherboard.
  11. Upon replacement, simply push the battery into the motherboard. Upon replacement, simply push the battery into the motherboard. Upon replacement, simply push the battery into the motherboard.
    • Upon replacement, simply push the battery into the motherboard.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Tom
회원 가입일: 2010년 10월 04일
814 평판
안내서 7개 작성하였습니다
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 회원
CPSU-MANESS-F10S22G4
4 회원들
안내서 26개 작성하였습니다
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
neverts “itchytastyurr” ennud - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 11,281
