이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Lay the computer on its side; you will see a blue knob.
Turn this knob 90 deg clockwise.
Slide the panel case forward about 1/2 inch while knob is turned.
Lift panel case off computer.
Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
Under the hard drive, there is a circular, silver battery connected to the motherboard.
Use a spudger to gently pry the battery from the motherboard.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 한 개
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
