주요 콘텐츠로 건너뛰기
Dell Optiplex SX280 Hard Drive Replacement
  1. Dell Optiplex SX280 Hard Drive Replacement, Panel Cover: 1 단계, 이미지 1/1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Hard Drive Replacement: 2 단계, 이미지 1/2 Dell Optiplex SX280 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Hard Drive Replacement: 3 단계, 이미지 1/2 Dell Optiplex SX280 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/2 Dell Optiplex SX280 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Dell Optiplex SX280 Hard Drive Replacement: 5 단계, 이미지 1/2 Dell Optiplex SX280 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Dell Optiplex SX280 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Squeeze the release tabs on either side of the hard drive.
  7. Dell Optiplex SX280 Hard Drive Replacement: 7 단계, 이미지 1/2 Dell Optiplex SX280 Hard Drive Replacement: 7 단계, 이미지 2/2
    • Slide the Hard Drive out while squeezing the tabs.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Wyatt
회원 가입일: 10/06/10
775 평판
안내서 6개 작성하였습니다
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 회원
CPSU-MANESS-F10S22G4
4 회원들
안내서 26개 작성하였습니다
댓글 2개
Thanks for great tutorial.
Politers - 답글
Yeah great tutorial!
Rebinas - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 5,832
