주요 콘텐츠로 건너뛰기
소개
Replace the Heat Sink on the Motherboard to maintain optimal performance
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Remove the large blue cover from the computer, there are no screws or tabs keeping it in place. Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
    • Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
  5. Press down on the release tab above the heat sink. Press down on the release tab above the heat sink.
    • Press down on the release tab above the heat sink.
  6. Pull the heat sink out of the computer while pressing on the release tab. When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
    • Pull the heat sink out of the computer while pressing on the release tab.
    • When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
결론
다른 4명이 해당 안내서를 완성하였습니다.
Tom
회원 가입일: 2010년 10월 04일
829 평판
안내서 7개 작성하였습니다
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 회원
CPSU-MANESS-F10S22G4
4 회원들
안내서 26개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 6,046
