주요 콘텐츠로 건너뛰기
Dell Optiplex SX280 Lower Fan Replacement
필요한 것
  1. Dell Optiplex SX280 Lower Fan Replacement, Panel Cover: 1 단계, 이미지 1/1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Lower Fan Replacement: 2 단계, 이미지 1/2 Dell Optiplex SX280 Lower Fan Replacement: 2 단계, 이미지 2/2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Lower Fan Replacement: 3 단계, 이미지 1/2 Dell Optiplex SX280 Lower Fan Replacement: 3 단계, 이미지 2/2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: 4 단계, 이미지 1/2 Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: 4 단계, 이미지 2/2
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  5. Dell Optiplex SX280 Lower Fan Replacement: 5 단계, 이미지 1/1
    • Remove the power supply by pressing the release tab. It is distinguished by the black, red, green, and yellow wires.
  6. Dell Optiplex SX280 Lower Fan Replacement: 6 단계, 이미지 1/2 Dell Optiplex SX280 Lower Fan Replacement: 6 단계, 이미지 2/2
    • Remove the rubber grommets from the base of the fan. The iFixit Opening tool may be useful in this step.
  7. Dell Optiplex SX280 Lower Fan Replacement: 7 단계, 이미지 1/2 Dell Optiplex SX280 Lower Fan Replacement: 7 단계, 이미지 2/2
    • Press on the blue release tab and remove the fan.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tom
회원 가입일: 10/04/10
841 평판
안내서 7개 작성하였습니다
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 회원
CPSU-MANESS-F10S22G4
4 회원들
안내서 26개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 18
전체 시간: 4,199
