주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Replace the Upper Fan in the computer tower to prevent overheating and computer damage.
부품
지정된 부품이 없습니다.
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Remove the large blue cover from the computer. There are no screws or tabs holding it in place. Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  5. Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires. Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
  6. Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful. Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful.
    • Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful.
  7. Pull the upper fan out of the computer.
    • Pull the upper fan out of the computer.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Tom
회원 가입일: 2010년 10월 04일
814 평판
안내서 7개 작성하였습니다
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 회원
CPSU-MANESS-F10S22G4
4 회원들
안내서 26개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 4,893
