주요 콘텐츠로 건너뛰기
Dell Photo Printer 540 Case Replacement
필요한 것
  1. Dell Photo Printer 540 Case Replacement, Case: 1 단계, 이미지 1/1
    • Rotate the photo printer so that the bottom of the case faces upward.
  2. Dell Photo Printer 540 Case Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
  3. Dell Photo Printer 540 Case Replacement: 3 단계, 이미지 1/1
    • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
  4. Dell Photo Printer 540 Case Replacement: 4 단계, 이미지 1/1
    • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
  5. Dell Photo Printer 540 Case Replacement: 5 단계, 이미지 1/1
    • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
  6. Dell Photo Printer 540 Case Replacement: 6 단계, 이미지 1/2 Dell Photo Printer 540 Case Replacement: 6 단계, 이미지 2/2
    • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
결론
Jonathan Mintz
회원 가입일: 04/04/12
11 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-7, Forte Spring 2012 Cal Poly, Team 14-7, Forte Spring 2012 회원
CPSU-FORTE-S12S14G7
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 630
